This is the continuing saga described in the previous post of 08-09-2003 where I fully explained the problems I have encountered regarding the valves on my 02 CRF-450 and the subsequent alterations accomplished to remedy said problems.
Having had two sets of Titanium valves installed with several shim adjustments on each set, as previously described, the time interval between normal operating lash settings for the intakes and essentially complete closure had decreased to the vicinity of less than 25 hours. At that point I had my Honda dealer install a complete set of Kibblewhite stainless steel intake and exhaust valves along with the appropriate Kibblewhite valve spring kit components to hopefully end my valve closure problems. Following said installation I did encounter the 'increased kick start resistance' problem mentioned ... but this is of minor consequence at the moment.
I have now operatied the bike on Michigan trails, relatively easy running conditions, for exactly 11.0 hrs ... on checking the valves yesterday I found both exhausts and the right intake to have maintained factory spec settings of 0.011" and 0.006" respectively. However, the left intake is now down to 0.003" ... all with only 11 hours operating time on my new stainless steel valves!
I intend to order an appropriate shim to install to regain factory spec setting of 0.006" for the left intake on Tuesday after the holiday; but ... this doesn't jive with the many posts I have read about installing Kibblewhite stainless steel valves in CRF-450's ... especially the Offroad.com CRF-450 Project series posting on these valves. They have been quoted as the solution for such problems which most of the experts have noted to be a function of either the original Titanium valves or the original Honda valve springs. Since I no longer have either of these ... the only other possibility for the new valves to be closing up so quickly would seem to be the valve seats in the head? Perhaps they are not hardened properly?
My Honda dealer freshly cut each of the valve seats prior to installation of the new steel valves ... each valve was hand lapped to match the seat ... compression is supurb ... why is at least one of the intakes still going closed after such a short period of operation?
I can restate that the official "honda" solution for my problem was to purchase a new head and install new honda spec steel exhaust and titanium intake valves ... purhaps the head suggestion is more important than just properly matching to the new titanium valves which cannot be lapped?
Anyway ... I am now in a severe quandry. If I reshim the left exhaust and it still closes up after only a few hours operation I am guessing that the only step remaining is to buy a new head and have my current steel valves put in it? Unfortunately I am not sufficiently mechanical to do this and the cost for the head plus removal of the old parts and subsequent reinstallation will cost on the order of $650 ... after I have more than $1500 in the motor to date trying to resolve this valve problem since its beginning last year. This is very disappointing ... almost seems like my motor is a "lemon" and I should patch it up and sell it.
Suggestions ... advice ???
