OK, it starts, it runs. For you who may have seen my earlier questions, I've got spark, I've got comp-ression and I've got the timing close enough to run. My newest challenge is when I come off the line the tranny seems to slip. It doesn't pop out of gear, it just doesn't grab consistently. It seems to slip and then, when it does grab, it practically rips my arms off the torque is so great. It is fine in the other gears and does downshift into first correctly. But slips badly in first. It also sometimes takes some force to downshift. Now I'me betting it's the clutch, but I wanted to see if anyone had faced this before. What do you think? Bad friction plates? Weak springs? Worn shift dogs? The bike sats for many years before I bought it and got it running again. I have no idea how good a mechanic the PO was, but I know he took the motor apart to clean it up. I redid the top end before I ran it. I also know the PO rides a mid-70s Gold Wing, so I figure he must know how to turn a wrench since no one can afford to pay someone else to keep an old beast like that running. Do you think the DT1 just needs to run a while to get the friction plates saturated or do I need to be looking for some replacement parts? If I pull the clutch how can I tell if the friction plates are shot?
