corners
mxer842
Subscriber
your gonna get a lot of ppl going both ways on this subject, but my thinking is that you should always have the clutch out. the subtle torque of the engine even at idle can vastly improve traction through a corner, i would downshift.
I personally don't think you should coast into a corner with the clutch in. You should choose the correct gear and slip the clutch if necessary to ensure you have the right amount of engine revs when exiting the corner. You should be either hard on the acceleration or hard under brakes - no coasting.
wardy
2005 Lori Nyland Award Winner
#4
thats way to broad of question since every corner is different. do a search on this forum for cornering and you will find may questions and answers.
wardy
