Hi
I need your help to solve my problem with my bike.
I´ve had the problem for a long time but it seems to get worser.
I´m fouling plugs and the bike is spooging a lot, the rear fender is black. The bike isn´t running to good.
I´ve checked a lot of things, and I´m going to check two more things. The ignition timing and if there´s any leak in the crankseal to the gearbox, if it´s sucking gearbox oil.
What is the symtoms of a bike that has “bad timing”. Fouling plugs or what?
And what is the symtoms of a leaking crank seal?
I have no tools for checking ignition timing and no tool for checking cylinder compression. So how do I know if the crank seal is worn out?
And how can I check if the ignintion timing is set incorrectly, there is no mark stamped on the stator. I can turn the stator clockwise or unclockwise, how will that affect the timing?
Thanks for the help!
