DConwheels
- Oct 21, 2006
- 15
- 0
I have a '93 Cr125 that is hard to start. I can usually bump start it and once it is going for a while I can start it again with no problems. If I try to cold start it I usually get nothing. My routine is: pull choke, kick moderately 2-4 times, push down choke and kick and kick and kick and kick and kick. If I don't turn throttle it sounds real muffled and no activity. If I turn the throttle it sounds as if it is trying to start but never really does. I recently took off top end, replaced gaskets, clean everything put new rings in, kept same piston, repacked silencer, cleaned carb 3 times, new plug, and new gas. Any ideas why it would not work with no throttle but closer with throttle open? Thanks for the help.
