Might you be able to provide me with the origional valving (shim stacks) for a 91 CR250 rear shock? Have a couple of old shocks with completely different shim stacks and not sure which one is closer to stock. The compression adjuster on my origional shock had no effect to the resistance and am trying to determine if its valving or the adjuster. Thanks
