- May 1, 2001
- 1,452
- 0
I'm putting crank seals in my 01 KTM 250, and have read that a bad crank bearing can cause a seal to go out. My question is this: No bearing can be PERFECT, right? The rhs crank bearing has me concerned. When you grab it a shake it, you can't see or feel any play, but if you listen carefully there is a slight noise. I'm hoping this is normal, as the bike has not had a hard life. I really don't want to split the cases...
