RECENT POSTS
Crank Seal
I have a 96 CR125 with a bad crank seal on the clutch side. Can anyone tell me how involved it is to change this seal? I have enough mechanical ability in that I 've changed the other crank seal, however I'm a little apprehensive on the clutch side. Much input would be appreciated! :laugh:
lets see, I think if it's the main bearing seal you gotta split the cases, pull the crank, all that. But if it's the outer crankcase seal I think you can do it by just removing the clutch assembly and whatever. I think...anyone else??
