CRF Showa damping rod "sucked" into the cartridge
Yoken
56
Hi everyone,
I just purchased a used 07CRF450 with about 10 or 15 hours on it. The fork was revalved by the previous owner and it is equipped with a subtank. I don't think the suspension company who did the work is relevant here, so I'll keep their name on the side. But here is what happened :
One of the fork seals was leaking so I decided to replace it. When I got the center bolt loose - with the fork slightly compressed - the damping rod did not stick out a couple inches like it usually does. I had to pull on it to expose the lock nut. I finally got both nut and lock nut out and the damping rod got sucked half way into the cartridge!
After refilling/bleeding the cartridge, I can not really picture putting the cap back on and create a vacuum at the same time. That doesn't make much sense. So the vacuum must have been created after the fork was reassembled.
Could a faulty subtank valve cause that? (I haven't check them yet...too cold in my garage these days!)
Or is it just by strapping the bike down for 6 or 7 hours on the trailer with a leaky seal?... the pressure would have leaked past the seal, then creating a vacuum once the bike was back on its stand with the fork fully extended...
In any case, it appears that the vacuum was transferred from the air chamber into the cartridge via the damping rod seal.
Has anyone experienced stuff like this before?
Thanks,
Yoken
56
Mxneagle,
In fact, the faulty seal appears to be on the ICS spring holder (that piece with the o'ring and the two bushings). I reassembled the cartridge twice and ended up with the sam problem: The cartridge is not building up enough pressure during the bleeding process and the damping rod does not extend all the way out. It stops about 3" short. And when I pull on the rod I can hear air being sucked into the cartridge from under the cap assembly... quite surprising for a bike that has only 10 to 15 hours on it...
Have a good weekend,
Eric
