bikewriter
TT Gold Member
Reged: 10/04/02
Guess I should post a ride report, huh
#757344 - 11/04/03 10:42 PM Reply Quote
Crazy busy at work but I got the chance to go out for about an hour. Mind you, I know full well what new-bike euphoria is. It makes you think your bike is the best no matter what so I'll keep this as objective as can be.
First thing I noticed is the rear suspension's static sag is much less than any bike I've owned. It's almost non-existant. But I set the rear up with 100mm of sag and we'll go from there. Take most bikes off the stand and let them sit, and they squat. The CRF250 doesn't. Maybe it's new-bike stiction. Who knows.
I've had good luck breaking in motors by not babying them. I run them hard but not for more than 10 - 15 minutes at a time. With the cold evening air, the CRF is letting me know it has a good motor. It is not dead down low like I thought it would be. Good oomph in conjunction with the weight. Once you get the rpms up, it has a strong and meaty range.
The bike's motor does not give you the floating sensation like a CRF450 does. You know how the 450 can come alive and spit you off the back in any gear at any time? The CRF250 is not like that in any respect. It does not feel that much lighter relatively speaking than my 450 but it's, what, 17 pounds less.
There is no early sign off or low-end bog. The motor is very good and I'm a believer of "if you don't notice it then it must be good." A lot of times a bike with what seems a killer top end is really a bike with absolutely no low or mid and a decent upper. The CRF250 has the power and torque and rpm and gearing exactly where it should be for a 250 four stroke.
Of course first gear is tall and top gear is low. That's what a mx bike is, right?!!
Handling and fit and all that is typical Honda great. I know for a fact the handling will not be the source of any complaints in turns or jumps or how it acts in midflight.
All in all it is really a great attempt at a "baby CRF450." I think the light weight and robust 250 motor is going to make this a fun and no-nonsense bike for the track and even the occasional tight off-road singletrack.
