Maybe the clutch was going out already and the fresh oil just made it more pronounced. If your "budget" (a funny word when used with what is basically a toy) doesn't allow you to spend more on consumable you've got some problems because oil won't fix a worn clutch.
never mind i found out what my problem was the oil had better friction performance and didnt mix with the wet clutch i put some new 4 stroke dirtbike oil in it and it better
