- Feb 6, 2006
- 255
- 0
I'm about to do my first top end and the wiseco piston instructions say to hone the bore and then chamfer the ports after honing. I have a steel lined cylinder and will be honing it with the 240 grit aluminum oxide flex hone that Eric Gorr suggests. What do I use and what do I need to do to chamfer the ports after honing? Also what technique should I use to actually do the honing? I assume a slow speed on the drill and move it up and down to maintain a 20-30 degree angle on the cross hatch? Should I run the hone all the way out of the cylinder top and bottom or just part way, etc? Thanks in advance.
