Cylinder Stud Bolts
I know this is probably a stupid question:
I am changing out me cylinder and need to switch the cylinder studs to the new cylinder. How do you remove the studs from the cylinder?
thanks in advance
whyzee
Never enough time !
smart to swap them out!
double up two nuts on the stud against each other, spray some penetrating fluid on the studs and then back em out. Do the same thing to install but use a torque wrench.
