fairdinkum
- Aug 10, 2002
- 4
- 0
Hi Jeremy,is the cylinder Valve replacement kit that Race-tech supply a better option than the suspension-tech bottoming kit for the Kayaba forks on the WR450f?Which one works better?
Also does the valving specs come with each one or do you have to revalve yourself?
As i live in Australia it is not a option to send my forks to you.I have all the shims and the tools to remove the cylinder valve's as i did my Wr 250 Last year.Mark Hammond sent me the shim stack to try and it works great.
Thanks for your time.
