I just purchased a 90' Honda CR 500, not running, sort of... The owner thought it had a jetting problem. Won't kick start (bump starts), no idle, rev's poorly but sputters above 5K rpms. In an attempt to throw parts @ the problem he installed a new plug, carb, ign. coil, pick up coil/ stator and top end. I decided I would go thru the basics- carb clean, plug new, ign coil within specs, pick up/ stator within specs, reeds shut/ none broken, exhaust clear, new fuel, clean air filter. Now provided the bike runs bad what next? Can CDI's cause perf. problems or do they just die? How about leaking crank seals? Any help or guidance would be great. Thank you
