A friend of mine needs to replace the forks on his 99 CR 250. What diameter are the forks on a 99 CR 250 and what other year(s) are the same diameter and have the same caliber bracket?
Hi. You could use the search function on the www.racetech.com website. It shows some statistics of each year's suspension parts, such as Showa/KYB, diameter, USD/conventional, etc.
The overall length of the forks changed...I beleive in '02 (5mm shorter)with the new chassis(not sure if they changed from '00 to '01). '02 and up you would need the newer axle and left side wheel spacer, '04 would have to add the brake carrier bracket.
What parts are bad? I have a complete Showa Kit forks for a '99 if interested.
