Nov 10, 2007
I know brakes are usually very easy and straight forward.However i am having trouble removing the caliper.The bolt going through the pads and caliper seems stuck or i just dont know wtf im doing.I dont know if you have to tap it from one side or turn it...There looks like you can put a flathead screwdriver in there.However it is not turning.Im sure there is a easy solution.I appreciate all the help.Thanks
IndyMX
Crash Test Dummy
5,548
Amo, IN
That flathead screw is just a cap.. get it out, then you need to take a allen wrench to the bolt.
Those caps can seize up.. And be quite the pain in the a$$ to get out.
Nov 10, 2007
Thanks man im gonna put a torch around there.Thanks again
elcamino12sec
412
Yes, like he said. Heat it up with a torch and they should be easy to remove. Replace with a little antiseize on the threads. If they are stripped out you may have luck on the auction site for a used caliper.
