Tony Yz426f
7
The kid that owned the 426 before me tightened the drain plug to tight and when i took it out to change the oil the aluminum threads where in the threads of the bolt. i put some Teflon thread tape around it but it leaks oil... now that i got it back together and road it when i parked it in the garage it has an oil leak on the drain plug and suggestions????
julien_d
1,788
helicoil, or drill and tap for a larger bolt. Another option is a universal rubber oil drain plug, kinda cheesy but does the trick.
