bobbyhill925
- Aug 28, 2005
- 234
- 0
Is it possible to re-port your engine thats been ported to raise compression?
quintwatson said:Are you just trying to lower your compression back down for pump gas? If so, try just running a thicker base gasket, or stack two standard ones. That will lift the cylinder slightly and give more room between the piston and cylinder head.
