RECENT POSTS
ebc clutch
Hi there, I am new to the forum hope someone can help. I just put in a new ebc clutch kit. springs steel and fiber plates. In the first two rides the clutch seemed grabby and inconsistent. I pulled it apart and I had a few steel plates in backwards. I was told sharp machined edge out? I noticed the springs in my new kit are about 3/8 of an inch shorter than my old ones is this right? My basket is in good shape no notches and everything else appeares in order. Has anyone else replace thier yamaha cliutch with aftermarket and noticed a grabby poor performance? The stock yamaha has a bit different setup with a seat plate, clutch damper spring, then friction and steels. The new ebc kit eliminates the seat plate and clutch damper spring. Any help or advice would be apreciated. Thanks.
as far as the springs go they are prob shorter due to the fact that they are higher strength. make sure you have your cable adjusted correctly.
