First: How can you check and see if your electrical system is working properly. Second: My KIPS is installed correctly but is sluggish to return into the idle position, which I think may be causing/contributing to my smoking problem in low RPM ranges and a loss in bottom end power. Would a new exaust advancer spring or a new advancer unit solve my problem, also does the spring even lose it's preload? Specs: 96' KDX 200, new bottom/top ends, new seals, reeds, air filter. FMF Gnarly pipe w/a FMF power core II silencer also w/new packing on the way, jetting #45pilot and #158 mian, modified the air box: snorkle removed and (5) 1/2" holes added behind the snorkle hole.
Thaks for your input,
Deeno
Deeno
