My son's bike has a problem with full throttle, the bike has a Franco Morini engine 50 cc, that has been ported by a local tuner ( Mr Rivara). The bike is very fast and responds well. However, I have had a Power Blade fitted to the carb to improve
bottom end performance. The carb fitted to the bike is a Dellorto PBHL 24 mm and the engine was ported for this carb.
Since the carb has been modified, when I open the throttle to 3/4 the engine revs reay well however, when I go to full the engine dies, and the revs go up and down.
Is this problem due to either a main jet that is too large or too small ?
I have cleaned the carb out, and the reeds fitted are carbon fibre and are quite thin. Do you think that if I get some thicker ones, this could be the answer.
