dman2091
15
Hi,
Im looking at buying an '01 YZ125 but it has been bored to a 144 and stroked as well. My local MX Association does not allow an engine to be stroked but it edoes allow it to be bored up to a 144. Is there a way to cancel out the stroking by buying a new part or would i have to buy a whole new thing and get it bored again?
kaboom1371
100
I would say you need to replace the crank and the rod back to stock. usually if you stroke a motor you put a longer rod and a crank with more throw. and new piston and rings.
ask the guy what he did to stroke it would be your best bet. and thats what you need to replace.
You can't change the stroke without changing the crank.
A new crank assembly from Hot Rods or Wiseco or something would probly the most economical way to go.
Tom68
407
Check that it really has been stroked in the first place, you may be able to get a measure through the exh port if not you'll only have to pop the head.
When was the last time you actually saw an engine tear down at a race? Just ride it as is and save your money for fresh tires and chains. ;)
I thought that same thing, but figured someone would start the "that's cheating" thing, lol.
Unless you're a damn fast rider no one will know. I've never heard of a mid-pack rider being protested.
