engine mount
97 kx250, I went to Pull the top end off, and grabbed the motor, and i removed the top front mount, the back mount where the swing arm bolt goes through was really loose (motor was sloppy on the bolt). Is there supposed to be a bushing in there or is the case junk?
a454elk
Mexicutioner
#2
Go onto the parts online and look at the fiche. Mine has a bushing holding it centered.
