first day on a dirt bike!!! a few questions
huskey89
52
hi everyone, today i bought my first dirt bike, a huskey cr 125 2002. i had a blast riding it today (although i never got out of third). I had a few questions. First when i had the clutch in after i started it and i shifted into first, it kinda jumped foward a very little bit, (makes me think that it is bad for the transmission), the guy i bought it from just put a new clutch cable on it this morning. So i figured out how to adjust the cable but i don't know how tight to make it. What is the rule of thumb here?
I accidentally started it with the muffler plug in once, any harm from that?
What regualar maintenance should i do to the bike? (stuff like every ride or every few hours)
And what oil/gas ratio should i use for this bike?
thanks,
nick
2strokerfun
1,500
My bikes usually do that and no harm ever done.
You want a little play in your handle before it starts to pull cable: about 1/8" or so
If there were, we'd all be looking for new parts. Shouldn't harm anything.
Clean and adjust chain periodically; clean and oil filter ever few rides; change transmission oil ever couple of rides (about 8-hours of running for me); eyeball everything before every ride; After about 20 hours or riding, it is a good idea to pull the cylinder and visually inspect the piston, cylinder and rings and measure them.
You're always pretty safe with 32:1
kschilk
90
I'd urge caution on the pre-mix...check the product label. Anymore, there are alot of concentrated oils out there and often, they recommend 40:1 to 50:1 ratios...some are even higher.
kschilk
90
flying flea said:
A Husqvarna CR 125? Isn't a CR honda?
Nah, Husky makes a CR...maybe it's made, now...I really haven't kept-up. Husky always used to make 3 models in each class...the CR, WR and OR. The CR was for MX, the WR was more for CC & Enduro and the OR, was pretty much a desert sled. As I recall, according to the old mfgr's literature, the designations denoted the tranny...i.e. Close Ratio, Wide Ratio and Open Ratio. Honda didn't start using CR, until the Elsinores...the '73 CR250 was first, the CR125 came in '74.
huskey89
52
another thing that i noticed that i forgot to mention was that on the swing arm, right side, the weld before the bearing where the rear axle is, was definitively rewelded. the weld looks to be in pretty good shape. what could have caused this and is it necessarily bad? worst comes to worst in a few years i need to get a new swing arm. how much does one cost?
IndyMX
Crash Test Dummy
5,548
Amo, IN
whenfoxforks-ruled said:
Chrome moly swingarm? Maybe not that expensive, if you can find a decent one.
Based on the pics I just looked at, it's not chrome moly, it's aluminum.. Looks pricey to me.
huskey89
52
could it possibly be rewelded? also my brother turned it over on its side today. what should i check for to see if he did any damage? besides scrapping up the hand guards.
IndyMX
Crash Test Dummy
5,548
Amo, IN
It was probably just an ugly weld from the factory..
How hard did your brother lay it down? These bikes are designed to take a good amount of abuse before you really have to worry about much.
But, I'd look at the radiator on the side he dropped it on, and anything else under the plastic that could have gotten bent.
huskey89
52
well it is definitely not an ugly weld from the factory, it was definitely at one time broke completely. the weld looks like it was a home job and it is only one one half of the swing arm, outer side. Could a professional do a good job reweldding this?
huskey89
52
and he was starting out on gravel going down hill, gave it way too much gas, lost control and he went one way and the bike another, i was quite pissed. the plastics got pretty scratched up. ill check the radiator and stuff tomorrow in the light.
IndyMX
Crash Test Dummy
5,548
Amo, IN
Sure, if it makes you feel more secure, by all means, have a reputable welding shop fix it up for you.
I'd hate to have to ride something thinking the rear wheel was gonna fly off.
How sure are you its a repair? Are there any visable cracks? There are some places you can ask about used parts. I would bet that europe would be an easier used parts market.
huskey89
52
i am 100% it is a repair, and the weld looks like it is cracking, not good. good idea with the europe market, got any sites?
I have had issues with UK websites, some sort of different language? Local to me are Halls, real good guys. Put a lot of e mails out to the parts scavengers. They hear you need parts, one disappears somewhere. MAY try like an overlay patch, take it to someone specializing in welding aluminum. Its broke now, so what the heck?
