1994 yz 125
need to know what float level to set , should it be 16mm as mentioned in the stickied guide ?
also it seems like you have to use quite the force to get the tang to push down the valve i really doubt just the float force of the.. float will make the job, is any pressure affecting this when running the machine or i ssomething wrong ?
i just got the bike so i have nothing to compare with if its right or wrong, but simply holding the carb upside down will NOT shut the valve, i have to apply a good deal of pressure to get it to close
gonna try get pictures of the assembly today
