Apr 26, 2007
23
I transport my CR 125 on a trailer, do I need to adjust them in some way before or after I secure them to the trailer. I thought there was some screw at the top of the inverted forks that need releasing?? Any suggestions would be great thanks
IndyMX
Crash Test Dummy
5,548
Amo, IN
Best bet is to get something that you can use to keep the forks from compressing.
I have a "fork saver" that my dad made from aluminum. Works great. However, prior to that I used a piece of a 2x4 cut down to size. It also worked pretty good.
Chili
Apr 9, 2002
8,060
11
Compressing the forks for travel is a non issue, no need for any devices. The screw you are referring to would be to bleed the air out, we usually do it after riding but not after transporting the bike.
IndyMX
Crash Test Dummy
5,548
Amo, IN
I find I am able to get the straps alot tighter with the device in place.. Less bouncing on the trailer, less chance of a strap coming loose.
Mar 16, 2007
471
I dont quite understand how your fork saver thing works. I usually just compress the forks and strap the bike down. So the wood keeps the forks from compressing? Where does the fork rest on it?
Chili
Apr 9, 2002
8,060
11
I've never had an issue securing a bike but if they work for that then it's worth it for your piece of mind. They aren't needed to save your seals etc like they advertise most of those fork savers though.
In our enclosed trailer I actually tie the bike down with turnbuckles to the footpegs with the bike on a center stand to avoid the use of tie downs all together.
IndyMX
Crash Test Dummy
5,548
Amo, IN
That's about the best way to do it...
knowiam
191
There was a great thread that Jeremy wrote regarding the "urban myth" of blowing seals whilst tiedown.... it just don't happen.
I had problems with our bikes coming loose crossing R/R tracks or unplanned bumps. I now strap the front tire down [in addition to the rear] and I synch the "bagezzus" out of the forks.
My pulse and blood pressure is with in prescribed operating parameters.
Ken
motodr9
184
I get leaky seals from riding in goo, not from tying my bike down. I have pogo'ed my way down 4x4 "roads" and have not had a tie-down come off.
I thought I might put my handlebar through my rear window a few times! (SUV with moto-tote on rough fire roads)
That being said, inspect and replace your tie-downs when they look beat.
Your on your own if a tie-down breaks.
