hey guys....i'm changing the oil in my forks(gonna make em firmer) anyways..i got the old oil draining over night and i was wondering if i have to bleed air or anything when i put the new oil in.......thanks for the input
Bry
yes u'll have to pump the air out of the cylinder by moving the fork piston rod up/dn about 10 times.then move the outer tube up/dn for the air between the tubes.let it sit bout 5 min for any bubbles to rise out....done
after you've pumped the air out of the piston rod, fill up the oil up to where you can see it then lift the outer tube and put your hand over it to make a seal- then push down. do this until no more bubbles can be seen then suck out the excess oil to the desired level.
