camaro_guy_z28
- Mar 10, 2007
- 57
- 0
Hello all tonight i went to open the front brake reservoir on my kdx and i discovered that one of the screws is totally rounded off. Any ideas on how i could get this screw out? Thanks
Green Hornet said:I 2nd the CRAFTSMAN EXTRACTOR.....Best $20 I have spent
Rotorranch said:Use a Dremel with a small, nearly worn out cut off disc. Cut a straight slot in the screw, and use a straight blade screwdriver to remove it. You can usually do it without cutting a groove in the cover.
When you get new screws, get steel, and get allen heads. You won't have an issue again.
Rotor
glad2ride said:Get a hand impact driver. No need to break out the drill just yet.
