I own a GG EC300 ‘03 here in the UK. I’ve had the bike for approx 10 months and love it. Unfortunately it has developed a niggling fault which I will try and describe for you in the hope that someone can help me pin point the cause.
The basic problem is engine misfiring. This is intermittent but is a real pain when it occurs. This is what happens…
1. Engine difficult to fire up and dies if you blip the throttle.
2. Won’t rev out when throttle is twisted at tick over.
3. A bit like leaving the choke on?
4. Feels like someone’s put a plastic bag over the air filter.
5. Very little power from standing start in 1st gear. If I do manage to get her rolling then it will run but very lumpy and will die if you don’t keep the revs up. Runs like a pig.
6. Runs great for months then fault appears for no reason. This has happened on and off for the 10 months I’ve owned the bike.
I’ve replaced the coil and kill switch but haven’t touched the alternator. I’m not convinced it’s the alternator as I guess this would either have a good (or bad) output all the time and not be intermittent?
OK - over to you guys. I’m assuming this is an electrical fault and causing a weak spark perhaps. Anyone think it could be carburation?
Looking forward to your replies.
