euro gasgas
287
It is described in the owner's manual - if you are lacking one, an '02 owner's manual (called service manual, but it isn't) can be found on the gasgas rider's club website - www.gasgasrider.org - look under manuals.
jeff
'01 gasgas ec300
www.gasgasrider.org GasGas Rider's Club
www.lt-racing.com GasGas Performance Products
ian hall
14
The manual talks about measuring the clearance from top of swinging arm to underside of chain.Do i need to disconnect the shock to find the tightest point?
gusgas
5
With the rear suspension fully extended (bike on stand), pull the chain upwards from the rear end of the chain slider.
The gap between the bottom side of the chain and the top side of the swingarm should be between 30 to 50mm (1 to 2 inches).
Jaybird
Apprentice Goon
6,452
Charlestown, IN
That's quite a window there, gus. Is that how the GasGas manual states the procedure?
