sickofitall
14
what is the best gear combo for my yz 250 i like to ride fields and stuff so i like to go fast. i go kinda fast now but i rip throught the gears pretty fast like i am topped out in like 100 feet it is geared like crap any help would be great cuz i know there is more speed to get out of this thing...
76GMC1500
I'm geared 14/51 on my CR250. It's good for 70mph or so on the top end. What is your current gearing? Count the teeth on the sprockets.
sickofitall
14
i run 14/50 i dont know if that is stock gearing.. but i need to go way faster.. there is a kid by me and he has a 125 and it is faster then my 250 wich is a little ambarrassing (sp) i dont think 1 tooth will make me go faster will it?? any help would be great thought thanks much
sickofitall
14
it just seems weird to think that one tooth will make that much of a diff. will i go fast if i do a 15/51 gear combo? or can you even do that? see gearing is not my strong point i just know that the speed i have now is not enough i want to go blazin fast that is why i got a 250 cuz i heard they do like 75 80 is that even true??
sixds
779
one tooth in the front is equal to three or four in the back. front sprockets are cheap so you could get 1 tooth bigger and 2 teeth bigger.
sickofitall
14
i clocked my bike today and with 14/50 gearing it will only go 45 what is up with that how many gears does a yz 250 have 5? or 6? 45 just doesnt seam that fast..
IndyMX
Crash Test Dummy
5,548
Amo, IN
Based on the manual for that bike... It should have a primary reduction of 3.0, trans reduction of 0.952 and final reduction of 3.571 (50/14)
At 10500rpms, you should see about 79.6 mph.
If you have the factory gearing in the trans and are running in 5th gear wide open, you should get 79 or so out of it...
adam728
1,011
Sounds like something is wrong with your bike. 45 is way too slow, and 14-50 is stock gearing.
One of the biggest complains about the YZ250 is that it needs a 6th gear for more speed! But still, most people report stock top speed to be in the 60-70 mph range. Out here there are a handful of guys that run 15-50 gearing, I'll be one when my current setup is shot.
sickofitall
14
i think i need a top ens change i am leaking oil out of my pipe where it meets the cylinder and where it meets the silencer it started out to be a litle now it is starting to run down the swing arm i dont think that is good i have also dicided that i am goin with a 15/50 gear setup yeah i knew 250 went way faster then 45 thanks for all the help if anyone else has a good idea about this problem let me know..
sickofitall
14
i think i need a top end change i am leaking oil out of my pipe where it meets the cylinder and where it meets the silencer it started out to be a litle now it is starting to run down the swing arm i dont think that is good i have also dicided that i am goin with a 15/50 gear setup.. yeah i knew 250 went way faster then 45 thanks for all the help if anyone else has a good idea about this problem let me know..
