piperpilot12
6
I have an old scooter that I just changed the tires on. Before I put it back together I should probably grease the bearings. What is the proper way to clean and grease a wheel bearing and what type of grease is needed? I do have Maxima waterproof grease.
Peer Lovell
If the bearings are sealed, you will have to remove the seal with a very fine pick. Then flush them out and re-grease. If you remove the bearings they have to be replaced as they are damaged on removal.
