Quiksilver
- Dec 14, 2003
- 19
- 0
It all started after my brother rebuilt a KX. It would smoke really bad then the spark plug would burn out. We replaced the cylinder head gasket and checked if the barrel was warped. I was slightly so we sorted it out. Now it is not to bad but it still floods itself. It runs really good but if you drop the revs then the bike will die out. You have to clean the spark plug before it will run again. The carb is all good, could it be the reed valves? Also the coolant drains out of the overflow loads. This could be because the cap is not the right pressure and lifts cos it is from another bike or is it related to the previous problem?
