Ok, hopefully you guys won't have to hear me moan about these issues again, but I've got several ideas of what might have happened to my bike and nothing really conclusive. Just guesses. So here is my situation and specific info.
Bike, 2001 RM250 - pc pipe/silencer, uni filter, carbon reeds, milled head, Carb jetting = 162 main, 52 pilot (standard = 162/48). The needle appears stock and in 3rd position. Air screw 1/2 turn out.
Elevation is 500ft, temperature was 50-60ish when riding, gas was 32:1 Klotz and 93 octane, and I rode for about 3 hours. Plug is a BR8EG (standard)
Before I took ownership of the bike, it had a couple hours on a brand new crank, wiseco piston and rechromed cylinder, however the previous owner ran race gas and did not tell me anything about this until after the fact.
How the bike acted- It had an up down rythmatic idling. Realy jerky and bucky down low. At the right throttle (1/8th or so) it would pop and knock a bit too. Over 1/2 throttle or so and it would run pretty good. Top end was fine.
Compression test on a cold cylinder showed 200 psi. Upon removing the head I noticed a small piece of the piston gone. Small chunk the size of a square keyway right in front of the arrow on the piston top. Cylinder showed no scoring so it looks to have passed out the exhaust.
Piston was very dark in color and had some slight pitting around the middle to exhaust side top of piston. No major pitting, just minor stuff. Cylinder head showed no pitting. Top side of the rings were very dark (kind of blued) and bottom side of rings were clean looking.
I'm wondering about three things at this point. (1) Me running too low a grade of gas causing intense heat and detonation (2) jetting being way off (3) powervalve protruding too far into cylinder causing chunk of piston to go flying.
If anyone has some hypothesis on what was the most likely scenario it would be great. Someone said when their cylinder was rechromed, the rings were clipping the valve and caused the same thing. Last night I manually moved the piston past the exhaust port and couldn't see any contact with rings to exhaust valve, but maybe if it were hot it could contact? Thinking I may want to take a sanding roll to the exhaust valve just in case.
At least this time I've got pics of the bike:
http://members.tccoa.com/micahdogg/100_4136.jpg
http://members.tccoa.com/micahdogg/100_4137.jpg
Micah
Micah
