Phill
Can somebody please explain the physical operation of the High and Low speed adjuster on a 2001 model ohlins rear shock.
Thanks in advance
Phill
(2001)CR500AF
svi
126
Phill,
As far as I'm aware the shock for a 2001 CR500 is a 46PRC which just has the usual low speed compression and rebound damping, the high speed being internal adjustment of the shim stacks.
Phill
SVI,
Although my bike has the powerlpant of a CR500 engine, the frame is Cr250 (2001 model), Therefore the shock in my bike is a 46PRX not a 46PRC as you thought.The shock definetly has an external high and low speed adjuster.
Phill
(2001)CR500AF
Phill
SVI,
The serial number on top of the shock is hard to read without removing from the bike, but it appears to be HO 1921.
Phill
(2001)CR500AF
svi
126
Phil,
The low speed works in the usual manner i.e. needle and orifice and the high speed works by varying the size of the orifice into the oil resevoir.
Jeremy Wilkey
Owner, MX-Tech
Jan 28, 2000
1,453
Phil,
The low speed works against a needle but also has a shim stack that can "blow off" It tends to moderate marginal settings. The high speed works buy tenstioning a stack of larger area. It uses a spring and a tension ring to effectively increase or decrease stack stiffness.
Regards,
Jer
FRESH VIDEO
