Hinson Billetproof Clutch Basket with Cushions are so good they’re used by the race teams of all 5 major power sports manufacturers. With this clutch basket, you can also get smoother clutch operation, more consistent lever pull, longer clutch life, and better response in your engine performance. How? Because with the Billetproof’s billet T6 aluminum alloy construction and aerospace-grade production tolerances, oil circulates around your clutch plates better, resistance to heat deformation is increased, and optimal operating tolerances are retained better than almost any other basket out there. You also get a set of clutch basket cushions that are tougher than stock so they won’t fall apart even after seasons of full throttle riding.
