hot start
i was wondering what exactly hot start is and what it does. any help would be appreciated :bang:
p8nt4lifee05speed said:
I think it opens a valve and lets more air in. Not 100% sure but i think.
You are correct, it lets in more air and leans out the mixture so you can start an engine that may be flooded.
I thought it was to get fresh cool air into the combustion chamber .
When riding the bike for a while and the engine is hot, i thought you open the hot start button and cycle in some fresh cool air then kick it over.
Its worked for me.
Subscriber
A hot four stroke needs a lean mix to start. The hot start creates an air "leak" so the engine will start. Basically a reverse choke.
FYI do not forget to cut the hot start off.
If you leave it on it will seem as if your throttle is sticking and it will backfire a ton.
