rmc_olderthandirt
1,533
8
Don't expect to get any noticable improvement in horsepower. Believe me, the factory engineers are not stupid and they don't throw horsepower away for no reason. There are a lot of gimmicks sold to people who are hoping for cheap, instant improvements but the bottom line is that they simply don't work.
Is some cases you can barter your power: trade some off the top to get more on the bottom, or vice-versa. If you want to start making major engine modifications you can trade reliability for a bit more power by making some moving parts a bit lighter. You can modify the compression ratio and get a bit more power at the expense of having to use expensive racing fuel. The cheapest and least trouble improvement would be to bore the cylinder out a bit larger.
Modifying your air box is not going to do anything beneficial for you.
Rod
76GMC1500
Uhhh...
Air box mods are for dual sports and enduro bikes that are plugged up from the factory. The airbox on your CR85 breathes as well as it ever will in stock form. Focus your efforts on keeping your air filter clean.
devll1
Uhhh...
Oct 23, 2007
44
aight thanks guys.wow the simple and stuff that should proly be common sense i learn on here.i need people to tell me stuff bout bikes.my dad isnt smart with them at all
