How-To How To Install The Tusk PDS Shock Heim Joint Bolt Kit
RockyMountain MC
The Tusk PDS Heim Joint Bolt Kit is the ultimate upgrade for your lower PDS shock bearing. Included are 2 special collars and a bolt with a grease fitting that will allow you to grease and prolong the life of your lower shock bearing. The collars and bolt are built out of high grade steel to withstand the abuse these parts will encounter on your off-road adventures.
