cello
33
Just wondered what the servicible limit on this part ? Need to strip the bottom end and replace bigend bearing and wondered if its logical to replace the conrod + main bearings ?
The bike is a 96 on its second nicosil replating and third piston.
If I do need to replace the conrod - is there a alternative to using Husqvarna parts - tried carillo and they dont do any rods for MX/Enduro,s in their catalogue.
Cheers
Cello
cujet
826
5
I have never seen an aftermarket rod for the 250, however it seems like there should be one.
My Husky 1994 360 con rod went after 6 years (shortly after I started using Redline Racing oil). I replaced the rod and was still using Redline Racing oil. The rod failed agian in short order, probably due to corrosion. I then replaced the crank and have had no problems for about a year now using MX2t oil.
The rod kit was $220, the crank was $300. The time effort to change the rod is worth paying the extra 80 bucks for a new crank! Heck, some shops are now charging $125 just to change the rod.
If you choose to change the rod, make sure to set the rod big end side clearance at the LOOSE end of the specs. Not doing this will reduce the life of the big end bearing.
Chris
cello
33
Husky Dealer in USA
Can you recommend a good Husky dealer in the USA. Parts here in the UK are very expensive - £200 for a Conrod and Bigend !
If its reasonable enough , I,ll be travelling over to the goodole states with a fat wallet to burn some hard earned greenbacks.
Thanks for the info
