11: NEEDLE VALVE SET
(5NY1) 1137-001 Invalid $27.87, Replace this yearly! It will dump fuel into your engine,regardless of turning the gas petcock off,it does it when you turn it on! The float may even appear to work correctly,while you are riding it is puking fuel in! 10 year old bike,has anyone been drilling their own holes? Are the slide and needle in good shape? Have you removed and inspected the choke valve? Do you have an adjustable choke/idle? Are the floats properly set? How are the reeds and intake? On a 125 you are insane to run es plugs! Remember what this bike was made for! You never idle it for 5 minutes,radiators are warm it is good to go. Choke for a second,if necessary! Using the choke can tell you if it is rich or lean,so can looking at the plug. If the manufacture says 32:1 then what the hell is the deal that everyone has to go and screw with it! UNBELIEVABLE and yet,wait a week! It is basic,it is simple and routine,and it says so in the manual! Air filters,clean,dry,oil and wring out,DONE! Other than allowing time to dry the filter,I would guess this can be done in a couple hours.
