will0203 said:well i already have the radiator off, but i dont know where the leak is coming from
will0203 said:well even when it was on the bike i couldnt find it, but i know that its at the bottom, would it be possible to just run jb weld along the bottom, where im assuming it is comming from?
IndyMX said:If you can fill it with water, and plug the hose connections, and pressurize it with an air compressor, you should get water forcing out of the hole.. Which should make it easy to locate the spot you need to repair.
will0203 said:ok and the only reason it goes in the oven is to get all the liquid out? And then you put the jb weld on after that right?
Matt90GT said:stick a raw egg down the radiator. Saw it on myth busters. Works!
although I would never do it to my bike, car, truck, boat or anything unless in dire straits.
will0203 said:and I just let the JB weld air dry?
