bradball
24
my vin is 5x8-051740
a dealer told me that it was an 83 but today i saw 2 83's for sale and the exhausts were on the opposite side of mine and i'm getting worried because i just ordered some parts and i hope they work. I emailed yamaha weeks ago but nothing as to a response. Can anyone help me?
XRpredator
AssClown SuperPowers
13,510
I believe the IT175 had become an IT200 by then (1982)?
dirt bike dave
5,349
The first year of the IT200 was '84.
The IT 175 was made from '77 to '83. The oldest ones have the exhaust pipe on the left side. The newer ones have the exhaust on the right side. What parts did you order? While I think the bike got two major renovations between '77 and '83, there might be some things that interchange.
1980 on top
1983 in middle
1977 on the bottom
dirt bike dave
5,349
FWIW, with the exception of a front disc brake, the much newer RT180 seems quite similar to the '80 IT175.
bradball
24
i have a round headlight, exhaust on right side i ordered **** for an 83 they just came in wheel bearings and all cables etc.. sure hope it's an 83 lol
bradball
24
yamaha dont know how to reply to emails and i was told by a dealer but i dont trust 1 opinion u knkow? there's tons of 80-81 175 parts on **** now and i'd like a coil etc... and just dont know if they'd work
anyne know how i can get quck help on my vin num ber? i 'm ready to order tons o **** and i'm broke so IT MUST BE CORRECT lol
thanks guys
regards
brad
2stroke
399
Wow another Yamaha ID question!
5X8 051740 was a 1983 IT175K.
(5X8 was also the prefix for 1982, but they had a lower serial number.)
bradball
24
clip position? u know of any charts to show me since i'm a mechanic dummy?
takes me 10 mins to find the right socket lol
i know the needle on that big piston ur u mean that lilk nut like thing w/ a minnie 1/4 springed needle on it? a valve or jet? sorry i'm so new at this lol
thanksk for all ur help guys
bradball
24
2 strokes for life said:
bradball, if it is running lean you need to raise the clip position on the needle.
clip is the U shaped thing? how many jets are in my carb 1?
sorry for all the q's just trying to figure how to move that clip position
i went to here for a carb pic 83 it175
http://shop.powersmotorsports.com/pages/parts/viewbybrand/2/yamaha.aspx
can u tell me which is the clip i need to try to move? remember it only starts and runs at full choke
thanks all
bradball
24
hey 2 stroke
i figured what needle u were talking about
a C clip w/ 5 positions
i tried them all and it only starts in position 2 and still only fires and runs w/ choke on guess i better sell more on e bay to take to shop :( CRAP
cbmain
Have you checked for a vacum leak? If you are sucking in more air from a leak the only way the motor would run would be to add more fuel-such as full choke. Spray some WD40 around the carb manifold/gasket area while the engine is running and listen for a change in rpm's.
Jan 3, 2007
1,860
bradball, do what cbmain said, and also spray it around the base gasket and head gasket. I thought that guy cleaned the carb and it worked fine. Also, check the inline fule filter, fule lines and blow some air past the jets and let the jets soak over night. Otherwise this is just getting me.
bbcountach
i've got an 82 or 83 it175. does anybody have any advice on where i can get another rubber intake boot? I need one that mounts the carb to the engine, and i can't find one anywhere. Any advice is greatly appreciated!
-B
