Jeremy W. or Anybody:
I have a 2001 YZ250 and would like to lower the seat height an inch or so. Right now I have adjusted the rear shock ring out by 3 turns and that helped the seat height a bit. I know there is a range to work within. If I change the rear shock ring to the highst length--less spring preload. What will I need to do to the front to keep it balanced. Is this an acceptable way to lower the seat height without cutting the seat foam. Also, anybody fooled with the subframe. It really isnt that bad I can tip-toe it now with a 30" inseam and 170lb frame. Just got back into riding since the 1970's so you can imagine the seat height change---but what a hoot, the plush suspension is just amazing. thanks
