I have a KDX 200 2001 the carb is rejetted to a 45 pilot, 155 main with the clip second from the top, I use a Br7 range plug and a 12t front sprocket. The bike runs great with lots of power I only need to occasionally adjust the air screw for good throttle responds based on temp, humitity etc. I gave the bike to my son and I bought a KDX 200 2002 broke it in, now has about 80 miles on it rejetted the carb to a 45 pilot, 155 main with the clip second from the top installed a 12 t front sprocket installed a Br 7 plug, installed a FMF K35 pipe, kept the stock silencer and installed boyesen power reeds, snorkel is off and fine tuned the pilot. The bike has very little pulling power in 6th gear and 5th is not that great. Moved the Clip to the middle position and power delivery only slightly improved in high gears, but still not good. The stock 2001 KDX with 600 miles is snappier and has a great power band in all gears. So I was thinking of pulling the power reeds out and tune just to the pipe first, then install the power reeds and tune to the pipe and reeds. Any suggestions, I was really supprised that after spending hundreds of dollars the stock bike runs better. What did I miss. Both bikes are run with 93 octane gas and yamalube at 40:1 mix. Riding is at 1000 ft elevation with about 50% humitity and 60 deg temp.
