Hoffies
41
I recently fitted Trailtech Vapour computor to my 2007 KDX 200. It has a rev counter, but am not sure if it is functioning correctly. Does anyone know typically at what approx. revs the KDX idles, and what typically a KDX should rev to(maximum)?
CaptainObvious
Formally known as RV6Junkie
3,331
From 1,000 to 10,000
adam728
1,011
Idle will vary greatly depending how you have it set. One person might feel 1200 rpm is a "normal" idle, someone else might feel 2800 rpm is a "normal" idle.
If you were to pull all the way through a gear, say 3rd, you should probably peak and be ready to shift by 8500-9000 rpm. I doubt you'll get a KDX to pull much past 9K, that's well beyond peak power.
