Today I went to bleed the air out of my forks using the screw on the top of the fork leg. It was the first time doing this in about 10-12 rides. As it goes, when I unscrewed the left fork leg screw nothing came out, but when I did the right side quite a bit of air came out. My question is, is this because one fork leg is ajusted differently than the other? All I have done is play with the clickers at the bottom of each leg and Im sure they are both the same amount of clicks out. Could it be the oil level?
thanks.
thanks.
