muckyduck
4
I have a 1998 KDX200. On tickover the revs increase/decrease
on their own, also when coming to a halt when riding the revs stay high for a time. I've checked fuel, filter, air leak (sprayed with WD40 no effect)cleaned carb with no joy. She fires up ok and on full throttle goes fine....Its got the KDX 'rattle' which is a little quieter when pulling the clutch in, could it be mains seals leaking, losing vacuum causing bad carburation? Any ideas,thanks for reading... Muckyduck
ebeck
199
Compresion check is next. If you have bad seals it will suck in the oil from the crank case. Are you loosing oil?
