Canadian Dave
Super Power AssClown
- Apr 28, 1999
- 1,202
- 0
GS you've replaced the clutch plates, did you measure the clutch springs while you had it apart?
Have you checked to insure the power valves aren't carbon seized, a very common problem. Pull the pipe and have a look up into the exhaust port. The sub port valves should be in the fully closed position. From your description it sounds like one or both of the valves may be stuck in the open position.
If you are going to do some work on the carb i.e. rejetting pull the carb off the bike and make sure its clean inside and out. Run to some place like Canadian Tire and pick up some carb cleaner. Disassemble the carb and go to work. Don't blindly start changing jets. Clean the carb and record what jetting is presently in the bike, including the jet needles clip position, and go from there. The stock jetting is likely too rich. A good starting point would be a 30 pilot jet, stock jet needle in the 2nd from the top clip position and a 330 main jet.
Have you recently done a compression check or serviced the top end?
Have you changed the spark plug?
The sprocket isn’t the problem though it is certainly worn out.
David
David
